basic card model almost done
mixture of resin and bondo used to stiffen it up then fibreglass mat on the inside
bondo used to build up the basic shape
filling and sanding and spray filler
after the shaping and sanding phase i got it into the primer stage
started building up the mouth area with bondo atached to a piece of foam and foil used to prevent it sticking to the opening
test fit of the mouth section,don't look to bad at this stage
Splashed a bit of silver paint on it just to see what it may look like,all this was sanded again to remove small errors in the surfaces
it's just about finished now except for the grey side panel needs doing and the visor area needs painting black,i know that a real Chrome finish is the best for this and anything else sucks but i have a pretty good finish that i will show in some pics later on as i'm waiting for some good daylight to do it as the pics indoors don't show the true finish,
this is my first try at Pepakura building and i'm very happy with the results so far,what do you guy's think,,good bad or just crap
