Customized Dalek "clock"
This 2003 edition Dalek is very well produced, with "talking" function and alarm clock with lighting up dome lights and eye.
The details are very good, however, I still found extra details to add, giving a more authentic model.
On the dome, I painted silver metallic on the light fittings.
The eye required a small washer to complete the lense.
On the grill bars, small rivets are located at the joins, which I added with a hot pin and epoxy, then painted to blend in with metallic gold.
Other details, such as hex screws and battle damage are also added, along with the identity tag under the eye shaft, painted in white.
I highlighted the bolt heads and the detail on the arm housing with a lighter shade of bronze metallic,
then the body casing is dirted down with a black wash.
DALEK CLOCK 2003 EDITION
Re: DALEK CLOCK 2003 EDITION
The bolt head highlights are perfect.
They really bring the figure to life.
