Does anyone have a good 3D Printable Centurion Helm
LordStarFyre
Post by LordStarFyre » Thu Jan 16, 2020 2:38 am
Hi
I have been looking for a good 3D printable model of the Centurion Helmet. As screen accurate as possible. Even better if the grill and eye section are separate elements (Maybe a 3D scan of one of the kits?)
There's a couple floating around on thingverse that are close, but no cigar.
Also looking for a good version of the Viper Helmet (same problem as above)
Re: Does anyone have a good 3D Printable Centurion Helm
Post by Cylon-Knight » Mon Jan 27, 2020 10:03 pm
I don't have one, but we need to track some down and host them here - on By Your Command.net!
I know a 3D modeler... I'll have to try and challenge him with some Classic BSG goodness (and badness :cylon:).
MackUK
Phalanx Member
Post by MackUK » Wed Mar 11, 2020 2:22 am
I’m currently in the process of modelling all the cylon parts in 3D for printing.
My only concern is the chroming process requires a lot of heat once printed and prepped for that lovely toaster look. This may cause the whole thing to warp or sag when in the oven. Strengthening with resin may be the answer, but who wants a heavy lid?
I’m nearly finished with the helmet and once done I will post on here. Sadly that thing called work gets in the way!
The back pack, I’ve gone for as near as possible to the original, and stayed well away from the Krop look!
Sent using Tapatalk
punisher75
It’s my birthday
Post by punisher75 » Fri Mar 20, 2020 10:13 pm
Sent using Tapatalk
The Chrome can he done as a chemical process like a mirror it doesn't generate any heat, it's typically called hydrochrome.
MackUK
Phalanx Member
Post by MackUK » Sat Mar 21, 2020 6:08 am
Sadly there’s no one local in the UK that offers that service. It’s hideously expensive for those that do.
Sent using Tapatalk
hutt-trooper
Post by hutt-trooper » Sun May 17, 2020 2:12 am
This would be super-awesome if you do complete these file - and are willing top share them.Legend.
MackUK
Phalanx Member
Post by MackUK » Sun May 17, 2020 2:16 am
I have most of the files done. I’m working on the last part now... the lid.
Watch this space.
Sent using Tapatalk
punisher75
It’s my birthday
Post by punisher75 » Tue May 26, 2020 11:31 am
Very interested! Can never have enough Cylon parts 😁
MackUK
Phalanx Member
Post by MackUK » Tue May 26, 2020 3:00 pm
Absolutely. I’m having a couple of issues with the lid as it’ll print from one piece, unlike the krop which is two pieces. The nose /mouth vent will be incorporated into it. Depending on supplier I’m trying to make the roving eye slide into a recess with clips rather than be glued in, so can be removed if service is needed. I will also use the
Mohawk as an air intake from the rear, and use a partition within the top of the Lid to Chanel fresh cool air which will blow from above. With work and all it’s a very slow process, but I’m hoping to have done soon.
Sent using Tapatalk
punisher75
It’s my birthday
Post by punisher75 » Tue May 26, 2020 6:38 pm
Sounds like you have some interesting ideas! Look forward to seeing them.
Jmvgreek1
Post by Jmvgreek1 » Thu Jun 17, 2021 10:01 pm
i do not know how accurate it is but if anyone is interested in 3d print armor files then contact Jeff woodward via facebook or try woodtecharmory@gmail.com he has created full cylon armor, colonial helmets eagle/pegasus and colonial dress medallions he is selling a copy of the 3d files for $50.00 attached below is some pictures of his work.
Post by Cylon-Knight » Mon Jul 19, 2021 8:56 pm
ACK! That centurion is going to have cold fingers and toes. lol
Those are all amazing models. Brilliant work!
Thanks for posting up the pics and info.
:salute:
