Cylon Rifle with Lights and Sound
welshchris77
Re: Cylon Rifle with Lights and Sound
Post by welshchris77 » Wed Jul 25, 2018 7:47 am
Pretty much finished, the two halves have been tapped together, greeblies glued on and electronics all successfully tested, yay!
Video link electronics test
https://www.dropbox.com/s/hr7rp15lb76rm ... 8.mp4?dl=0
Chris Lewis
Post by Red Eye » Wed Jul 25, 2018 11:32 am
Very nice tutorial!
Thank you for sharing.
Post by Cylon-Knight » Wed Jul 25, 2018 12:15 pm
EPIC BUILD!!!
welshchris77
Post by welshchris77 » Wed Jul 25, 2018 6:02 pm
EPIC BUILD!!!
Very nice tutorial!
Your very welcome, thanks for the support.
If anyone is interested I can put up the wiring diagram and code needed to do this :wink:
Chris Lewis
Soda Can
Post by Soda Can » Thu Jul 26, 2018 6:40 am
:loveit: that is a very nice build, yes to the diagram and code please.
What will be next.
I would put two sound files on this, the first classic cylon blaster sound, the second for a laugh would have to be a pew pew sound file.
Post by Cylon-Knight » Fri Jul 27, 2018 2:35 pm
PEW PEW!
I love it. #sold ;)
:evillaugh:
Soda Can
Post by Soda Can » Fri Jul 27, 2018 3:19 pm
I thought it would be a good idea to make those lowly humans do our bidding, especially if everyone is going to be able to talk in character thanks to the roland VT3, this would sound a bit odd with a cylon doing the pew pew.
Although in saying that, that could be another good sound file, maybe :cylon:
welshchris77
Post by welshchris77 » Sat Jul 28, 2018 6:05 am
Ok folks I have put together the wiring diagram, code and parts list :D
If you would like the files in a higher resolution email me here and I will send them to you welshchrisinireland@yahoo.co.uk
I can also send the sound file!
I am in no way a programmer so my code may be a little scrappy, some of it is adapted from a Stormtrooper E11 code used on a different project, there is a section in it for a rotary switch that is no longer being used, I tried to remove it but it seemed to affect the circuit so I just left it in, it doesn't affect the way the rifle operates so use the code as it is or feel free to tinker with it if you wish.
Also there is a slight pause with the sound on the first press of the trigger (no idea why), after that it works fine.
You might want to move the on/off switch to a different position, where I placed mine it was getting knocked off by my glove, I solved it by rewiring the switch in reverse so it gets knocked on rather than off, if that makes sense!
****Important!!!!!, Please be careful when wiring, if you look closely there are basically two power circuits 7.2v from the battery, this powers the led drivers and the Arduino, the rest is powered from the Arduino's 5v output, trigger switch, mp3 player, amplifier chip, dont mix these up or you may very well burn something out!
If anything goes wrong I take no responsibility!
Any questions feel free to ask :grin:
Code:-
Project "Cylon Rifle"
Version 1.0 : Light and Sound
// Define Pin layout
const int PinTrigger = 2; // Trigger function
const int PinLED1 = 5;// Led closest to Trigger
const int PinLED2 = 6;
const int PinLED3 = 7;
const int PinLED4 = 8;
const int PinLED5 = 9;
const int PinLED6 = 10;
const int PinLED7 = 11; // Led at nozzle
// Define const for Firing modes
const int FireModeSingle = 1; // DigitalValue (0001)= Rotarypos 1 for Single fire mode
const int FireModeBurst = 9; // DigitalValue (1001)= Rotarypos 9 for Burst fire mode
const int BurstMode = 3; // Amout of sequence repeats on one trigger action
const int Hold_Delay = 50; // [msec] time the trigger must be pushed before activation
const int DelayTime = 50; // [msec] delay between LEDs
const int DelayTimeEnd = 200; // [msec] duration of LED at nozzle
// Variables
int TriggerState = 0; //Reads status of Trigger
int SwitchValue = 0; // Readout of Rotary switch
int SequenceRepeats = 1; // Amount of sequences per Trigger
int PreviousState = 0; // PreviousState of Trigger
unsigned long TimeTriggerPressed; // Time at which the trigger is pressed
boolean SequenceStart = false; // Allow Sequence to Start
void setup() {
// Setup pin modes
pinMode(PinTrigger, INPUT); //Trigger
pinMode(PinLED1, OUTPUT); // Pin Led1 (closest at trigger)
pinMode(PinLED2, OUTPUT);
pinMode(PinLED3, OUTPUT);
pinMode(PinLED4, OUTPUT);
pinMode(PinLED5, OUTPUT);
pinMode(PinLED6, OUTPUT);
pinMode(PinLED7, OUTPUT); // Pin Led7 (Led at nozzle)
digitalWrite(PinLED1,LOW); //Turn off led1
digitalWrite(PinLED2,LOW); //Turn off led2
digitalWrite(PinLED3,LOW); //Turn off led3
digitalWrite(PinLED4,LOW); //Turn off led4
digitalWrite(PinLED5,LOW); //Turn off led5
digitalWrite(PinLED6,LOW); //Turn off led6
digitalWrite(PinLED7,LOW); //Turn off led7
Serial.begin(9600); //Baudrate
Serial.write(0x7E);
Serial.write(0x03);
Serial.write(0xA7);
Serial.write(0x1d); // volume (hexadecimal conversion 1-31 --> 1f = max / 14 = medium)
Serial.write(0x7E);
void loop() {
TriggerState = digitalRead(PinTrigger); // read trigger status
// Check state Trigger
if (( TriggerState == HIGH) && (PreviousState == LOW)) { //Mark pressing moment
SequenceStart = true;
TimeTriggerPressed = millis();
if (( TriggerState == HIGH) && ( PreviousState == HIGH) && ( SequenceStart == true)) {
if (( millis() - TimeTriggerPressed) >= Hold_Delay) {
for(int x = 0;x<SequenceRepeats; x++) {
// play Led sequence
digitalWrite(PinLED1,HIGH);
delay(DelayTime);
digitalWrite(PinLED2,HIGH);
delay(DelayTime);
digitalWrite(PinLED3,HIGH);
delay(DelayTime);
digitalWrite(PinLED4,HIGH);
delay(DelayTime);
digitalWrite(PinLED5,HIGH);
delay(DelayTime);
digitalWrite(PinLED6,HIGH);
delay(DelayTime);
digitalWrite(PinLED7,HIGH);
delay(DelayTimeEnd);
Serial.write(0x7E);
Serial.write(0x04);
Serial.write(0xA0); // A0 for SD card
Serial.write(0x00);
Serial.write(0x01); // track number
Serial.write(0x7E);
PreviousState = TriggerState;
Parts list, most with links
1. Arduino Nano (the software I use with this clone is 'Arduino 1.0.6')
https://www.ebay.ie/itm/Nano-V3-0-Mini- ... nrcpbSjN7g
2. WT5001M02 28P U disk Audio Player Card Voice Module MP3 Sound For Arduino&WS
https://www.ebay.ie/itm/WT5001M02-28P-U ... SwzaJX4N5D
3. 2 Channels 3W Digital power PAM8403 Class D Audio Amplifier Board USB 5V
https://www.ebay.ie/itm/10PCS-2-Channel ... SwRQlXdzT6
4. EN-EL9 7.2V 1200mAh battery 2 + LCD display USB charger + USB cab J9P8 (these are cheap chinese ones but work fine for me!, the nikon ones are really expensive)
https://www.ebay.ie/itm/For-Nikon-EN-EL ... SwbKRbP6gu
5. Led Diver
https://www.ebay.ie/itm/New-3W-700mA-DC ... 2380834ee2
6.1w led smd White
https://www.ebay.ie/itm/50pcs-1W-LED-SM ... 2749.l2649
7.1w led smd Blue
https://www.ebay.ie/itm/10x-50x-1W-3W-5 ... Z20-jHtbQA
8. 4Ohm 3W Round Inside Magnet Loudspeaker for USB Bluetooth Speaker
https://www.ebay.ie/itm/2W-0-5W-8Ohm-4O ... ayxCv6WG1g
9. Micro on/off switch
https://www.ebay.ie/itm/20pcs-lot-SS12F ... Swf-xZnsC6
10. Red Mini Lockless Momentary ON/OFF Push button Switch
https://www.ebay.ie/itm/10pcs-Red-Mini- ... SwxKtYBw2U
11. 1/8w 1kohm resistor
https://www.ebay.ie/itm/1000PCS-High-Pr ... SwuHJbD4fw
12. 1/4w 10kohm resistor
https://www.ebay.ie/itm/1Set-100pcs-1-4 ... SwqYBWmLyY
13. Solder
https://www.ebay.ie/itm/100g-0-8mm-60-4 ... 4b199ca121
14. Heat shrink tubing (sizes between 1.5mm to 3mm)
15. JST XH 2.5mm connectors and crimping tool (not necessary for the circuit but handy for maintenance)
https://www.ebay.ie/itm/50SETS-of-JST-X ... GK2XOKQVvw
https://www.ebay.ie/itm/Mini-Mirco-JST- ... SwevlaJ6h3
16. 22 gauge Wire (red and black mostly, I used different colours for the Led control cables but you could just use red or black either)
https://www.ebay.ie/itm/Equipment-Wire- ... xydlFSyOxp
17. A good quality soldering station (you will need it for fine soldering, below is the one I use but its up to you what one you choose)
https://www.ebay.ie/itm/AOYUE-INT9378-6 ... SwWxNatUeV
18. Solder sucker
https://www.ebay.ie/itm/190mm-Soldering ... Sw8FBbF6Op
19. Micro SD card (sandisk are good)
20. precision side cutters, wire stippers and mini needle noose pliers
21. Helping hands (you will use these a lot!)
Probably some other stuff I haven't thought of too, I will add if I think of anything else
Chris Lewis
Post by FLIGHTLDR SERPENTINE » Tue Sep 11, 2018 11:07 pm
Geez. Alot of work there!
Soda Can
Post by Soda Can » Wed Sep 12, 2018 3:42 am
Just a thought, can the leds and driver boards be swapped out with neo pixels?
welshchris77
Post by welshchris77 » Wed Sep 12, 2018 4:50 am
Soda Can wrote:Just a thought, can the leds and driver boards be swapped out with neo pixels?
I have never used neo pixels before but I guess you could incorporate them into the circuit, I believe neopixel run off 5v though you would have to tap into the output from the Arduino rather that the 7.4v batteries output I used for the LED's in this projectImage
Sent from my SM-A310F using Tapatalk
Chris Lewis
MackUK
Phalanx Member
Post by MackUK » Wed Sep 19, 2018 9:30 am
:frack: This is an awesome build. way beyond my electronics capabilities. But showing what it can do... amazing!!
I love this. For me, when I get my 3D printed one finished and sanded and stuck together, it'll be a flashing light at the front... that's it.
Well done on an epic build!
Mack
welshchris77
Post by welshchris77 » Wed Sep 19, 2018 10:49 am
Thanks Mack, the circuit is not as complex as it looks believe it or not, if you have any kind of basic soldering skills you could do itImage.
The fabricating of the bits to hold it all in was the trickiest bits to do.
MackUK wrote::frack: This is an awesome build. way beyond my electronics capabilities. But showing what it can do... amazing!!
Mack
Chris Lewis
MackUK
Phalanx Member
Post by MackUK » Sat Sep 22, 2018 2:52 pm
I'm good with soldering, but..
I don't know how to program the Arduino boards. I'm also not good with the schematics of the circuits between the boards. Also no good in making sure the initial circuit on the breadboard would work (I don't even know how to use one!) :erk:
I'm sticking with the flash light approach. Seems well within my capabilities.
Soda Can
Post by Soda Can » Sat Sep 22, 2018 3:19 pm
I'm in exactly the same position as you MackUK, i have never used the arduino boards or programmed anything up as yet.
But we have to start somewhere, I'm working on a bb8 and bb9 unit with some slow but will be positive results.
It's just a matter of reading through what everyone else is doing, I've just got a cr10s 3d printer recently also, it will be great for this hobby and fun to learn along the way.
Just keep asking questions, there's no harm in doing that, that's how we all learn and help each other out.
That is also why I'm a part of this and other forums, great people offering help to us newbies along the way, then we can pass the same onto others once we've grasped the basics.
Keep up the great work centurian, and we'lllook forward to seeing your progress. :salute:
