Lost Scene of the Gods
- Hope It Is The Grog
Thought this question might get lost in the other thread, so I'm posting it separately.
Does any known version of Lost Planet of the Gods include the scene with the cadets sitting at simulators while Starbuck says, "Don't force it. Remember, you're flying a Viper. Thinking what you want it to do is enough to make it happen"? This appears in the teasers before Part 1, but then the scene never happens.
Last edited by Hope It Is The Grog on Fri Oct 04, 2013 8:58 am, edited 1 time in total.
- Raider Gunner
Re: Lost Scene of the Gods
As far as I'm aware that scene appeared in the teaser only. It never appeared in a final cut of the broadcast episode, or the telemovie version.
Thanks. Quite an oddity.
NuBSG had the same problem. While I cannot remember specific instances (it's been too long), I do recall seeing many "previously, on Battlestar Galactica" scenes in the beginning that I don't recall ever happening in previous episodes. Nothing too catastrophic, but there were a couple that were some head-scratches, IIRC.
Now, come to think of it, when did it change from showing sneak-peek scenes in the beginning of an episode to scenes from previous episodes? Sometime in the 80's I think, but I can't honestly remember who started that trend.
Previews are always a bit quirky. The movie or tv show teaser company has full access to the captured production. They nor the producer is 100% sure what will or will not be used. Even after they discover the problem they just let it go as they did in the Galactica episode you mentioned. I also recall that certain clip you speak of.
Wow, I never even knew they had teaser companies.GoldCylon wrote:Previews are always a bit quirky. The movie or tv show teaser company has full access to the captured production. They nor the producer is 100% sure what will or will not be used. Even after they discover the problem they just let it go as they did in the Galactica episode you mentioned. I also recall that certain clip you speak of.
Well most TV shows are not out sourced to make the next week previews, but movie releases are. They shop around on Sunset Strip for the best tease that they can find.
- Raider Gunner
That's right, I've spoke at length with Jimmy Giritlian who cut the teasers/previews for many of Stephen J.Cannell series, and while Cannell Productions handled their cuts in house Giritlian said that he had access to all the footage and sometimes something he used did not make the finished episode.GoldCylon wrote:They nor the producer is 100% sure what will or will not be used. Even after they discover the problem they just let it go as they did in the Galactica episode you mentioned.
At least a couple of "next week" previews on Galactica did not have Cylon voices dubbed in, so the audience heard the person inside the costume saying the lines. While the scenes did actually appear in the finished episode, it does give a example of what kind of material the editor had to work with.
Now, that is cool.Scott wrote:GoldCylon wrote: At least a couple of "next week" previews on Galactica did not have Cylon voices dubbed in, so the audience heard the person inside the costume saying the lines. While the scenes did actually appear in the finished episode, it does give a example of what kind of material the editor had to work with.
(from the same deleted scene)
Starbuck: "Now, the actual combat flying will be easier than you think because the Cylons only have four moves. Believe me, you'll see them a million times."
