Building my Cylon-Knight
GoldCylon: Gloves - large then, I don't think I'd do well with "teen" gloves.
nashslash: R2D2 would a be GREAT item to build, that is a dream project. That takes LOTS of talent, time and money. Maybe Someday I can have a R2D2-Knight - VERY COOL your friend will help you out.
Mr Fett: I'm right there with you - a scanner for $60 I know that is possible. The actual parts are not that expensive... it is the knowledge of what/how to put everything together that is so elusive.
Red Eye: Yes, getting the armor will be so much fun! And I am getting the rest of my suit from the same source as the helmet - C.O.R.A. A great product, and great service! I hope to have a centurion that will be fit for service in your empire, oh illustrious Imperious Leader (costume owner )
A chromed R2D2 with a Red Eye scanner and ChrisD working some cross over of a Cylon R2D2 sound effects. The Star Wars Galactica cross over has begun. :idea:Cylon-Knight wrote:GoldCylon:
I'll let you know what I find for my scanner Mr Fett
I have a question for all you Centurions out there... I'm trying to fit all my parts together for the helmet - and need to know what to fill around the eye area.
See the area marked with the arrow...
Should the area where the two parts join be filled in and smoothed over to be seamless transition from part to part? OR is the little overlap (not a perfect seam) correct?
Another view just in case:
Permission granted, CylonKnight! You will be the first Centurion I'll affiliate in my army!Cylon-Knight wrote:GoldCylon: Gloves - large then, I don't think I'd do well with "teen" gloves.
Red Eye: Yes, getting the armor will be so much fun! And I am getting the rest of my suit from the same source as the helmet - C.O.R.A. A great product, and great service! I hope to have a centurion that will be bit for service in your empire, oh illustrious Imperious Leader (costume owner )
Back to the problem of your helmet: I hope the two close-ups of the Vulpa helmet here will help you solving the problem.
http://www.flickr.com/photos/dklimke/27 ... 2/sizes/o/
http://www.flickr.com/photos/jcolman/33 ... 0/sizes/o/
Small computer fans are your best bet when it comes to fitting them in the helmet. There are plenty of stormtrooper sites which may help you with installation.
CK - I have fallen in love with a product called 'Magic-sculpt' It is a two part resin which is very similar to those rolls you buy in the hardware store to fix anything from a coffee cup to a radiator. It works great to fill in those gaps, adds strength too! It can be worked with for about an hour or so and will smooth out with tools and water. When dry it is very solid but can still be sanded. I like this better than bondo because it wont crack. I would advice that you don't put it on any parts which need chroming though... I'm not sure if it will receive the chroming (it might - but I'm not sure).
That fan works off one 9 volt battery, ran down to my left cheek. My right cheek holds another 9 volt battery for my eye lights. Plus there's another spare 9 volt battery stored inside a section of the mowhawk. They are just all held in place by a piece of sticky back velcro stuck to the plastic of the helmet, and another piece stuck to one side of the battery.
Mr Fett:
Where did you get your fan from? I've looked around at a few computer sites, but they mostly sell square fans - that are either just back or light up for a computer case mod. I found mention of one fan that looks great (very small size) from a Stormtrooper site link, but no price?! Link to the fan here.
General question for anyone:
I wear glasses. Does anyone else wear them, and how do you deal with that while wearing your helmet? I was just wondering if anyone has a creative solution for the limited real estate within the helmet vs. your head + scanner. I think everything will fit (eye scanner and my glasses) but it will probably be a tight fit. (I
- nashslash
Cylon-Knight I wear glasses to, but imagine it would be next to imposable to wear them while wearing you lid (let alone trying to put the lid on while keeping your glasses in place). I wear contact lenses when I troop. I would look at the possibility at getting some contact lenses.
for a fan I use this
battery box with micro switch
http://www.maplin.co.uk/Module.aspx?ModuleNo=36603
and 2 fans in relay.
http://www.maplin.co.uk/Module.aspx?ModuleNo=32006
the box is small enough just to sit inside (attached with velcro for easy removal) the lower jaw space and the fans are fitted by the cheeks. photos to follow
