NASHSLASH Cylon Helmet Build
- nashslash
update.
I hate this stage loads and loads of sanding. during this process the bridge across the nose also cracked (because of the flex in the styrene) and I had to re-glue strengthen it apply more filler and start this part of the process again.
method
1. sanded the applied body filler
2. applied a coat of primer to the sanded filler to see what areas needed addition work
3 re sanded the area and applied a small amount of model putty.
I would say this stage is one of the most important. preparation is key if you want a seam free super smooth cylon. I won't rush this stage (as much as I hate it)and will take as I as it takes until I am happy to continue to the next.
The full Build Album can be found here...
http://s532.photobucket.com/albums/ee32 ... =slideshow
method
- nashslash
Update
still working on my lid. and this is the part I hate the most.
method.
1. using 800 grit wet and dry and primer
2. a question of sanding and priming. then reapply primer and re-sand.
3 I want to get a really smooth finish on this, so it's a question of keep going back adding more primer and re sanding until I'm 100% happy.
method.
- nashslash
Update
Just another update from today's work.
flatted the primmer using some 800 grit wet and dry. added a new cost of primmer. the seam is looking really good now as is the repair to the bridge of the nose. (you cant see it.) also started to prep the interior eye section.
things are looking good even if i say so myself.
- nashslash
going to be painting this bad boy Dale, but thanks ..
ok my lid build. i got a bit impatient today and decided to give it a quick blast with some chrome paint just to see what's it coming along like. you can really see any imperfections as this point. so far so good i say.. i took a few shots of the seams too. like i said i sprayed straight onto the primer and never gave it the proper undercoat of gloss black. need a little more work in a few places once its dried, then another primer rub down to flatten then a proper few coats of gloss black.
note it wasn't particularly sunny day when i took the photos.
- nashslash
just for this i used plastic kote Chrome
but i want to use Alcad when i finish painting it..
http://www.alclad2.com/lacquer_colors.html
painted in alcad 2 chrome
