MY TURN... (or "So it Begins...")
Re: MY TURN... (or "So it Begins...")
Post by FLIGHTLDR SERPENTINE » Sun Oct 12, 2014 7:39 pm
a little more today
Post by Cylon-Knight » Sun Oct 12, 2014 9:42 pm
Overlap, yep. I trimmed mine up quite a bit. What seem to be trim lines are not one a few parts.
Live the helmets.
The three stooges.
Post by FLIGHTLDR SERPENTINE » Mon Oct 13, 2014 7:43 pm
Just got home from work and had to do something towards the goal...
Post by FLIGHTLDR SERPENTINE » Mon Oct 13, 2014 11:03 pm
first fitting
Post by Cylon-Knight » Tue Oct 14, 2014 3:35 pm
You're not too fat... No such thing - big, small... Cylons rule them all! ;)
The angle of the curves around your shoulder/back is off.
One size fits most never works to hot, does it?
Post by FLIGHTLDR SERPENTINE » Wed Oct 15, 2014 10:38 pm
What exactly do you mean "The angle of the curves around your shoulder/back is off"?
And Cylon-Knight, a few more questions: was that just regular styrene adhesive, aka "model glue" you used to glue everything together? Like Testors? Will the Milliput pop off of the plastic, or does it bond well? I'm thinking of using it to sharpen some edges on the head, in particular. And also, when time to primer, is there a specific type of primer (definitely sandable) that is recommended for the plating?
Post by Cylon-Knight » Wed Oct 15, 2014 11:44 pm
Here we go...
Bright Blue - the angle of the curves (of the back pack - sorry)
Yellow - your shoulders/back
... that difference is why it seems "wrong."
For your questions:
  • I used regular Testors glue. Yes. I even added strips of sheet plastic on the insides spanning the seam. Glued everything up good and then Milliput the seams, and putty blobs on some inside corners for a bit more holding power.
  • Milliput can chip a bit, but overall sands and fills great. It is like any putty... you can smooth edges or sand a nice new sharp corner with it.
  • Primer, any would do... sandable, yes. Just ensure it (or anything) you use has no silicon in it - that will keep the plate from sticking.
  • And, yes, I gave you bunny ears
Post by FLIGHTLDR SERPENTINE » Thu Oct 16, 2014 6:33 pm
:bsglol: I didn't see the bunny ears until you said something! :nah:
Ok, so I took a look at real centurion photos and I don't see alot of difference in that angle. I am thinking maybe I just gave too much "girth"? :frak: I am s-l-o-w-l-y losing some weight, but maybe I should trim into the edge of that backpack a little for a better fit? I won't rush into this if I do.
Post by GoldCylon » Tue Oct 21, 2014 12:26 pm
I have seen small and big Cylon's. They have made the proper adjusts as needed to make it work. Cylon Knight is correct.
Post by FLIGHTLDR SERPENTINE » Tue Oct 21, 2014 7:24 pm
Maybe I should wear a girdle
Post by GoldCylon » Tue Oct 21, 2014 7:39 pm
[quote="FLIGHTLDR SERPENTINE"]Maybe I should wear a girdle
Post by FLIGHTLDR SERPENTINE » Thu Dec 11, 2014 4:21 pm
No progress for about a month now. Been focusing on the storm/flooding that's hitting the west coast this week and last.
Post by Cylon-Knight » Thu Dec 11, 2014 10:31 pm
Stick to the high ground, Centurion! Take care.
Post by FLIGHTLDR SERPENTINE » Fri Feb 20, 2015 8:25 pm
Still no further progress. I keep walking by the box of trimmed armor in the garage. The vocoder is calling to me. I probably won't get back to it until spring is solidly here though. Working 6 ten hour days a week right now. Not much rec time.
Post by FLIGHTLDR SERPENTINE » Wed Sep 02, 2015 7:59 pm
After a long break I plan to finish all my trimming and begin the gluing, filling etc. process this holiday weekend. Got lots o' time, as the family is going out of town. Rest assured, there will be pics.
:evillaugh:
